JBL Go 3 Battery Replacement
    1. JBL Go 3 Battery Replacement, Battery: step 1, image 1 of 2 JBL Go 3 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a Jimmy or opening tool to gently lift one corner of the fabric mesh, then carefully remove the entire fabric and shell.
      • Insert the Jimmy along the seam and gently pry open the housing.
      • Work your way around the speaker, unclipping the internal latches as you go.
      Ask FixBot
    2. JBL Go 3 Battery Replacement: step 2, image 1 of 3 JBL Go 3 Battery Replacement: step 2, image 2 of 3 JBL Go 3 Battery Replacement: step 2, image 3 of 3
      • Use a screwdriver to remove the screws securing the motherboard to the device.
      • Locate the battery, it’s usually wrapped in black or silver and connected to the mainboard by a small cable.
      • Carefully disconnect the battery connector from the circuit board.
      • Remove the old battery, replace it with the new one and reconnect the cable securely.
      • Close the housing, screw everything back in place, and reattach the fabric mesh.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kasey Oliver
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 20
Past 7 Days: 82
Past 30 Days: 340
All Time: 1,931
