JBL Go 2 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
16
Past 7 Days:
127
Past 30 Days:
445
All Time:
1,320
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
After long-term use of the JBL Go 2 speaker, it can lose battery life. If your speaker no longer holds a charge or dies quickly, replacing the battery can bring it back to better performance. This beginner's guide leads you through the steps to safely remove the old battery and replace it with a new one. Before you start your process, make sure to gather the necessary tools listed below to ensure proper restoration.
Tools
    1. JBL Go 2 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the JBL Go 2 is powered off completely before beginning.
      • Unplug the charging cable or auxiliary cord if connected.
      Ask FixBot
    2. JBL Go 2 Battery Replacement: step 2, image 1 of 1
      • The front speaker grill is clipped on.
      • Use a plastic pry tool or guitar pick along the edges.
      • Carefully work around the grill until it pops off.
      Ask FixBot
    3. JBL Go 2 Battery Replacement: step 3, image 1 of 1
      • Remove the four 9 mm T6 Torx screws that secure the driver housing.
      Ask FixBot
    4. JBL Go 2 Battery Replacement: step 4, image 1 of 1
      • Gently pull apart the front and back casing.
      • Be careful because internal wires connect the components.
      Ask FixBot
    5. JBL Go 2 Battery Replacement: step 5, image 1 of 1
      • Use your fingers or tweezers to carefully unplug the battery connector from the board.
      • Do not pull on the wires, only the connector.
      Ask FixBot
    6. JBL Go 2 Battery Replacement: step 6, image 1 of 2 JBL Go 2 Battery Replacement: step 6, image 2 of 2
      • Unplug the battery connector from the motherboard.
      • Once complete, the motherboard will release from the device.
      Ask FixBot
    7. JBL Go 2 Battery Replacement: step 7, image 1 of 2 JBL Go 2 Battery Replacement: step 7, image 2 of 2
      • When removing the battery, slowly lift it using a plastic pry tool.
      • Take care not to bend, warp, or puncture the battery during removal.
      • Peel it away from the adhesive.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elisa Llanes
469 Reputation
4 Guides authored
Texas Tech, Team 8-3, Johansen Spring 2026 Member of Texas Tech, Team 8-3, Johansen Spring 2026
TTU-JOHANSEN-S26S8G3
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 127
Past 30 Days: 445
All Time: 1,320
