JBL Flip 3 Battery Replacement
  1. JBL Flip 3 Battery  Replacement, Remove first protective cover: step 1, image 1 of 2 JBL Flip 3 Battery  Replacement, Remove first protective cover: step 1, image 2 of 2
    • Pry up the two tabs on one side.
  2. JBL Flip 3 Battery  Replacement: step 2, image 1 of 2 JBL Flip 3 Battery  Replacement: step 2, image 2 of 2
    • Pry up the other two tabs, they are located on the other side.
    • Be careful not to break the delicate buttons.
  3. JBL Flip 3 Battery  Replacement, Remove first protective cover: step 3, image 1 of 2 JBL Flip 3 Battery  Replacement, Remove first protective cover: step 3, image 2 of 2
    • Remove the cover.
    • Don't pull it too much, otherwise it could break.
  4. JBL Flip 3 Battery  Replacement, Detach second protective cover: step 4, image 1 of 3 JBL Flip 3 Battery  Replacement, Detach second protective cover: step 4, image 2 of 3 JBL Flip 3 Battery  Replacement, Detach second protective cover: step 4, image 3 of 3
    • Unscrew the four screws located on the edge.
    • The screws usually remain captive, if they fall off after all, put them aside.
  5. JBL Flip 3 Battery  Replacement, Remove second protective cover: step 5, image 1 of 1
    • Remove the second protective cover.
Repeat the same steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Lasse.gra
689 Reputation
4 Guides authored
2 Comments
What’s your problem?
Ali - Reply
Uncomplete and Sketchy!
How come is this a battery replacement guide? It is only up to the removal of the second protective layer. Many questions remain: How to locate the battery? How to unplug it? How to remove it? How to plug the new one? How to reassamble? …
Yusuf - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 3,056
