JBL Flip 3 Battery Replacement
  1. JBL Flip 3 Battery Replacement, Remove the first protective cover: step 1, image 1 of 2 JBL Flip 3 Battery Replacement, Remove the first protective cover: step 1, image 2 of 2
    • Pry up the two tabs on one side using a spudger.
  2. JBL Flip 3 Battery Replacement: step 2, image 1 of 2 JBL Flip 3 Battery Replacement: step 2, image 2 of 2
    • Pry up the other two tabs, they are located on the other side.
    • Be careful not to break the buttons, as they are fragile.
  3. JBL Flip 3 Battery Replacement, Remove the first protective cover: step 3, image 1 of 2 JBL Flip 3 Battery Replacement, Remove the first protective cover: step 3, image 2 of 2
    • Remove the cover carefully.
    • Don't pull it too much, otherwise it could break.
  4. JBL Flip 3 Battery Replacement, Remove the second protective cover: step 4, image 1 of 3 JBL Flip 3 Battery Replacement, Remove the second protective cover: step 4, image 2 of 3 JBL Flip 3 Battery Replacement, Remove the second protective cover: step 4, image 3 of 3
    • Unscrew the four screws located on the edge.
    • The screws usually remain in, but if they fall out, put them aside.
  5. JBL Flip 3 Battery Replacement, Remove the second protective cover: step 5, image 1 of 1
    • Remove the second protective cover carefully.
Repeat the same steps in reverse order to reassemble your device.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Lasse.gra
791 Reputation
4 Guides authored
3 Guide Comments
What’s your problem?
Ali - Reply Share
Uncomplete and Sketchy!
How come is this a battery replacement guide? It is only up to the removal of the second protective layer. Many questions remain: How to locate the battery? How to unplug it? How to remove it? How to plug the new one? How to reassamble? …
Yusuf - Reply Share
You're right, the current version does not answer your questions. However, it seems that 5 people could still successfully repair their device with the help of that guide, so rather than taking it down, we'd suggest you and others help complete the guide by adding your pictures and information you found?
Sandra Hiller - Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 116
All Time: 5,303
