Instant Pot 60 EPC Button Panel Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,016
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The following guide is from replacing the front panel of an Instant Pot 60 EPC. Consider following this guide if you have issues with unresponsive buttons, random error codes, or a flickering screen display.
Parts
Tools
    1. Instant Pot 60 EPC Button Panel Replacement, Button Panel: step 1, image 1 of 3 Instant Pot 60 EPC Button Panel Replacement, Button Panel: step 1, image 2 of 3 Instant Pot 60 EPC Button Panel Replacement, Button Panel: step 1, image 3 of 3
      • Ensure the device is unplugged and cool before beginning.
      • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
      • Remove the single Torx screw.
      Ask FixBot
    2. Instant Pot 60 EPC Button Panel Replacement: step 2, image 1 of 2 Instant Pot 60 EPC Button Panel Replacement: step 2, image 2 of 2
      • Turn the bottom face counterclockwise and remove it.
      Ask FixBot
    3. Instant Pot 60 EPC Button Panel Replacement: step 3, image 1 of 2 Instant Pot 60 EPC Button Panel Replacement: step 3, image 2 of 2
      • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
      • Remove the three Phillips screws securing the frame.
      • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
      Ask FixBot
    4. Instant Pot 60 EPC Button Panel Replacement: step 4, image 1 of 2 Instant Pot 60 EPC Button Panel Replacement: step 4, image 2 of 2
      • Disconnect the 8x1 pin control connector from the main board.
      • The plug should easily come up when pulled with slight pressure.
      • It may be helpful to also rock the plug side to side while pulling up.
      Ask FixBot
    5. Instant Pot 60 EPC Button Panel Replacement: step 5, image 1 of 1
      • Remove the single screw attaching the front panel to the main body with a Phillips screwdriver.
      • This screw may be difficult to get to; we were able to remove it by threading a screwdriver underneath the main board.
      Ask FixBot
    6. Instant Pot 60 EPC Button Panel Replacement: step 6, image 1 of 3 Instant Pot 60 EPC Button Panel Replacement: step 6, image 2 of 3 Instant Pot 60 EPC Button Panel Replacement: step 6, image 3 of 3
      • Remove the main body from the Instant Pot.
      • It should easily pull up with a little force and be free from the control board.
      Ask FixBot
    7. Instant Pot 60 EPC Button Panel Replacement: step 7, image 1 of 2 Instant Pot 60 EPC Button Panel Replacement: step 7, image 2 of 2
      • Remove the Phillips screw.
      Ask FixBot
    8. Instant Pot 60 EPC Button Panel Replacement: step 8, image 1 of 2 Instant Pot 60 EPC Button Panel Replacement: step 8, image 2 of 2
      • Pull the front panel away from the body and carefully pull out the wires that connect the front panel to the circuit board.
      • The front panel is now free to be replaced.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,016
