Installing an Iron-on Patch
  1. Installing an Iron-on Patch, Iron-on Patch: step 1, image 1 of 2 Installing an Iron-on Patch, Iron-on Patch: step 1, image 2 of 2
    • Examine the damage – cut off any long threads and clean off any debris.
    • Grab your iron-on patch.
    • We are using a contrasting patch for visibility, but you may want something that matches with your jeans or a fun contrasting color.
  2. Installing an Iron-on Patch: step 2, image 1 of 3 Installing an Iron-on Patch: step 2, image 2 of 3 Installing an Iron-on Patch: step 2, image 3 of 3
    • Preheat your iron according to the recommended settings found on the packaging information included with the patch.
    • Take a scrap of denim and place it inside the pant leg, beneath the hole.
    • This scrap material will keep your patch from sticking the front of your jeans to the back, which would effectively seal the leg opening shut (not a good thing...)
  3. Installing an Iron-on Patch: step 3, image 1 of 2 Installing an Iron-on Patch: step 3, image 2 of 2
    • Measure the length and width of the hole in your jeans, including any damaged area around the hole.
    • In our case the hole is about 1.5 inches by 2 inches.
  4. Installing an Iron-on Patch: step 4, image 1 of 2 Installing an Iron-on Patch: step 4, image 2 of 2
    • Add at least a half-inch in both directions to get your final patch measurements.
    • Mark your final patch measurements on the patch with tailor’s chalk.
  5. Installing an Iron-on Patch: step 5, image 1 of 2 Installing an Iron-on Patch: step 5, image 2 of 2
    • Cut the patch along your marks.
    • Round the corners of the patch, to prevent them from peeling up.
  6. Installing an Iron-on Patch: step 6, image 1 of 3 Installing an Iron-on Patch: step 6, image 2 of 3 Installing an Iron-on Patch: step 6, image 3 of 3
    • Lay your cut patch over the hole and position it where you want it.
  7. Installing an Iron-on Patch: step 7, image 1 of 2 Installing an Iron-on Patch: step 7, image 2 of 2
    • Iron the patch according to the package instructions, usually from between 30-45 seconds. Keep the iron moving and try to apply even heat to the whole patch.
  8. Installing an Iron-on Patch: step 8, image 1 of 2 Installing an Iron-on Patch: step 8, image 2 of 2
    • Run your finger around the edge of the patch to ensue that all the edges are completely bonded to your jeans.
  9. Installing an Iron-on Patch: step 9, image 1 of 3 Installing an Iron-on Patch: step 9, image 2 of 3 Installing an Iron-on Patch: step 9, image 3 of 3
    • Turn the pant leg inside out.
    • Gently try and lift the scrap of fabric from the inside of the pant leg.
    • If the scrap comes off, you no longer need it.
    • If the scrap is held firmly in place by the patch, simply trim away the excess fabric from where the scrap is adhered with your scissors, leaving the remaining scrap in place.
Brittany McCrigler
89,051 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 37
Past 7 Days: 303
Past 30 Days: 1,293
All Time: 214,055
