Introduction
Mettez à niveau votre RAM et optimisez instantanément la vitesse.
Desserrez l'unique vis Phillips au centre de la trappe d'accès.
Retirez la trappe d'accès de votre iMac.
À l'aide de l'extrémité d'un spudger, sortez les languettes de la RAM en plastique noir de la baie de la mémoire.
Tirez sur la languette de la RAM en plastique noir pour éjecter le module de RAM de l'iMac.
Pulling plastic tabs isn’t releasing the old ram board. How to get this out when black tabs don’t work
Black plastic tabs not releasing the old ram cards. How to get out?
Saisissez le module de RAM par les côtés et sortez-le de son emplacement en le levant bien droit.
graphic is not for the proper model iMac. For this series iMac there is only 1 pair (2 total) of memory slots, this graphic displays 2 pairs (4 total). Also there is a lever to eject the ram not plastic tabs.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
53 other people completed this guide.
Special thanks to these translators:
100%
Fabienne Detoc is helping us fix the world! Want to contribute?
Start translating ›
5 Comments
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
PH2 head necessary to remove screw.
airshack - Reply
Mine was as written, a PH1.
tpivo - Reply
