Introduction
The Insignia 2-in-1 Handheld/Stick vacuum brush bristles, over time, can get worn down from continuous use. The bristles in the head might get damaged and need replacement, or the head might be obstructed by debris. Use this guide to help replace the brush head in the event of imperfect performance.
Unscrew single 12.0 mm Phillips #2 screw on the right side of the bottom of the vacuum head.
Lift and pull up on the brush retention clip.
Pull brush up and out to replace.
