Insignia NS-BCDCAS1 Tape Cassette Player Replacement
  1. Insignia NS-BCDCAS1 Tape Cassette Player Replacement, Outer Panels: step 1, image 1 of 2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement, Outer Panels: step 1, image 2 of 2
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 2, image 1 of 1
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 3, image 1 of 2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 3, image 2 of 2
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 4, image 1 of 1
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 5, image 1 of 2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 5, image 2 of 2
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
  6. Insignia NS-BCDCAS1 Tape Cassette Player Replacement, Tape Cassette Player: step 6, image 1 of 1
    • Face the bottom of the opened boombox, and detach the front panel from the back in the following order:
  7. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 7, image 1 of 3 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 7, image 2 of 3 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 7, image 3 of 3
    • Unplug the 4 wires (1 red, 2 black, 1 white) from the yellow motherboard on the front panel, by pulling upwards.
    • Pull the black tape attached to the white plug on the yellow motherboard by tugging upwards.
    • Detach the thicker, white and pink cord on the smaller yellow plate on the front panel by pulling away.
  8. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 8, image 1 of 2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 8, image 2 of 2
    • Facing the inside of the front panel, on the corners of the grey plate, there are four screws. Unscrew these with a phillips 1.
  9. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 9, image 1 of 2 Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 9, image 2 of 2
    • Face the inside of the front panel. Push the buttons down gently to slide the cassette player unit out.
  10. Insignia NS-BCDCAS1 Tape Cassette Player Replacement: step 10, image 1 of 1
    • On the back of the unit to the right of the motherboard and between the motor and black circle, there is a rubber band that allows the spinning wheels to spin the knobs. Using tweezers, remove the rubber band and replace it.
Erin King
215 Reputation
2 Guides authored
CSU Fullerton, Team 2-5, Bruce Fall 2016 Member of CSU Fullerton, Team 2-5, Bruce Fall 2016
CSUF-BRUCE-F16S2G5
4 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 562
