Insignia Flex 8 NS-15AT08 Back Casing Replacement
  1. Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: step 1, image 1 of 2 Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: step 1, image 2 of 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Back Casing Replacement: step 2, image 1 of 2 Insignia Flex 8 NS-15AT08 Back Casing Replacement: step 2, image 2 of 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
Krystal Rhodes
488 Reputation
3 Guides authored
Baylor, Team 6-7, Williams Fall 2015 Member of Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 470
