Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓RAM is a vital component that helps your device run efficiently. It allows the system to open new tabs and temporarily store data.
If your device is running slowly, crashing randomly, failing to boot, showing application errors, or displaying visual glitches, the RAM is likely the cause.
This guide will show you how to replace the RAM in the Lenovo IdeaPad L340-15API.
Before you begin the repair, power off the laptop and disconnect the charging adapter and any external peripherals.
Parts
Tools
Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
