Shop the Holiday Gift Guide
IdeaPad L340-15API Battery Replacement
View statistics:
Past 24 Hours:
10
Past 7 Days:
62
Past 30 Days:
184
All Time:
939
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The battery is a critical component that keeps your device powered. It supplies energy to all parts of the laptop and must hold a charge long enough to make the device portable.
If your laptop can’t hold a charge or must remain plugged in to stay on, the battery is likely the cause.
This guide shows how to replace the battery in a Lenovo IdeaPad L340-15API.
Before you begin, power off the laptop and disconnect the charging adapter and any external peripherals.
Parts
Tools
    1. IdeaPad L340-15API Battery Replacement, Optical Drive: step 1, image 1 of 2 IdeaPad L340-15API Battery Replacement, Optical Drive: step 1, image 2 of 2
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
      Ask FixBot
    2. IdeaPad L340-15API Battery Replacement: step 2, image 1 of 2 IdeaPad L340-15API Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
      Ask FixBot
    3. IdeaPad L340-15API Battery Replacement: step 3, image 1 of 2 IdeaPad L340-15API Battery Replacement: step 3, image 2 of 2
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
      Ask FixBot
    1. IdeaPad L340-15API Battery Replacement, Battery: step 4, image 1 of 2 IdeaPad L340-15API Battery Replacement, Battery: step 4, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
      Ask FixBot
    2. IdeaPad L340-15API Battery Replacement: step 5, image 1 of 3 IdeaPad L340-15API Battery Replacement: step 5, image 2 of 3 IdeaPad L340-15API Battery Replacement: step 5, image 3 of 3
      • Insert a plastic opening pick in the back left corner and wedge the panel open.
      • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
      • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
      • Remove the bottom cover.
      Ask FixBot
    3. IdeaPad L340-15API Battery Replacement: step 6, image 1 of 2 IdeaPad L340-15API Battery Replacement: step 6, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
      • Use a container/magnet strip to store the screws while working.
      Ask FixBot
    4. IdeaPad L340-15API Battery Replacement: step 7, image 1 of 3 IdeaPad L340-15API Battery Replacement: step 7, image 2 of 3 IdeaPad L340-15API Battery Replacement: step 7, image 3 of 3
      • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      Ask FixBot
    5. IdeaPad L340-15API Battery Replacement: step 8, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Author
with
Ian
347 Reputation
2 Guides authored
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 62
Past 30 Days: 184
All Time: 939
