Introduction
The requirements for replacing the battery are the usage of a 4 mm Phillips screwdriver, a soldering iron station, a utility knife, heat shrink tubes and two lithium batteries (3.6 V). Make sure how to use a soldering iron, especially in combination with batteries. If you are not familiar with (replacing) batteries, it might be a good idea to search for some information about how batteries work. Last but not least, create a work environment with good lighting and a clean desk. The replacement requires attention and concentration.
Use a 4 mm Phillips screwdriver to remove the seven screws to disassemble the housing of the drill.
Place each new tubing (three in total) on the battery wires through sliding them on each wire.
Attach the two batteries to each other with tape, in case you have two separate batteries.
Use solder and a solder iron to attach the new battery to the wires.
Slide the tubings on each connection and heat each tubing with a lighter to make them shrink.
Put the housing back on the drill through clicking and closing it.
Put the seven screws back into the housing with the Phillips screwdriver.
