Introduction
This guide will show you how to replace your keyboard. Sometimes the keys get broken or worn out, or the track point gets damaged, thus needing it to be replaced.
Tool used on this step:Anti-Static Wrist Strap$7.95
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Four 18mm long M2.5 screws
Two 16mm long M2.5 screws
One 4.5mm long M2.5 screws
Four 3mm long M2.5 screws
Open the laptop all the way until it is flat.
Take the black circle off and remove the screw.
Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
