Huawei P10 Main and display flex disconnect Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Huawei P10 Main and display flex disconnect Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Main and display flex disconnect Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Main and display flex disconnect Replacement, Back Cover: step 1, image 3 of 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Main and display flex disconnect Replacement: step 2, image 1 of 3 Huawei P10 Main and display flex disconnect Replacement: step 2, image 2 of 3 Huawei P10 Main and display flex disconnect Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Main and display flex disconnect Replacement: step 3, image 1 of 2 Huawei P10 Main and display flex disconnect Replacement: step 3, image 2 of 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Main and display flex disconnect Replacement, Main and display flex disconnect: step 4, image 1 of 3 Huawei P10 Main and display flex disconnect Replacement, Main and display flex disconnect: step 4, image 2 of 3 Huawei P10 Main and display flex disconnect Replacement, Main and display flex disconnect: step 4, image 3 of 3
    • Remove the two Phillips #000 screws.
    • Use tweezers to remove both metal plates.
  5. Huawei P10 Main and display flex disconnect Replacement: step 5, image 1 of 3 Huawei P10 Main and display flex disconnect Replacement: step 5, image 2 of 3 Huawei P10 Main and display flex disconnect Replacement: step 5, image 3 of 3
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
Dominik Schnabelrauch
204,902 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 70
