Huawei P10 Charging Board Replacement
  1. Huawei P10 Charging Board Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Charging Board Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Charging Board Replacement, Back Cover: step 1, image 3 of 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Charging Board Replacement: step 2, image 1 of 3 Huawei P10 Charging Board Replacement: step 2, image 2 of 3 Huawei P10 Charging Board Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Charging Board Replacement: step 3, image 1 of 2 Huawei P10 Charging Board Replacement: step 3, image 2 of 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Charging Board Replacement, Battery disconnect: step 4, image 1 of 3 Huawei P10 Charging Board Replacement, Battery disconnect: step 4, image 2 of 3 Huawei P10 Charging Board Replacement, Battery disconnect: step 4, image 3 of 3
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Charging Board Replacement, Charging Board: step 5, image 1 of 2 Huawei P10 Charging Board Replacement, Charging Board: step 5, image 2 of 2
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  6. Huawei P10 Charging Board Replacement: step 6, image 1 of 2 Huawei P10 Charging Board Replacement: step 6, image 2 of 2
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  7. Huawei P10 Charging Board Replacement: step 7, image 1 of 2 Huawei P10 Charging Board Replacement: step 7, image 2 of 2
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  8. Huawei P10 Charging Board Replacement: step 8, image 1 of 2 Huawei P10 Charging Board Replacement: step 8, image 2 of 2
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
Dominik Schnabelrauch
203,906 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 33
All Time: 6,809
