Up to 20% off select tools
Huawei P smart Pro Display Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
92
All Time:
512
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 day
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
If your Huawei P smart Pro display is cracked, unresponsive, or malfunctioning, this guide will walk you through the process of replacing it step-by-step. The P Smart Pro features an LCD screen with a modular design, making the replacement straightforward with the right tools and careful handling.
Whether you’re addressing physical damage or display issues, following this guide will help you restore your phone’s screen functionality and appearance efficiently. Make sure to work patiently and methodically to avoid damaging delicate components.
Let’s get started on bringing your device back to optimal condition.
      • To start, remove the back glass by following these steps:
      • Begin by heating up your iOpener. For instructions on how to heat up your iOpener, see this guide.
      • Place the iOpener on the right side of your device (with the back glass facing you).
      • Attach the suction cup to the back glass and pull up.
      • Insert an opening pick and slide it to the bottom right corner.
      • Insert another opening pick and slide it to the top right corner.
      • At the top of the device, insert an opening pick and slide it to the top left corner. If needed, reheat your iOpener and place it on the edge before prying. Repeat this step for the bottom left corner.
      • You can now fully pry open the back glass.
      Ask FixBot
      • Undo all 12 screws to remove the metal shield.
      • Make sure to not lose the screws.
      Ask FixBot
      • Disconnect the ribbon cable that leads to the display with the Spudger (included with your iOpener Kit).
      • To avoid damage to the cameras, please disconnect them from the motherboard and temporarily place them in another location, such as a small bag.
      • Do not shake the bag to avoid damage to the cameras inside.
      Ask FixBot
      • Connect the new display and power on the phone, then test if the touchscreen works properly. If the display works as intended, power off the phone and proceed to the next step.
      • If the display does not work, you are advised to temporarily stop here and purchase a new one.
      Ask FixBot
      • Disconnect the ribbon cable to the battery using the Spudger (included with your iOpener Kit), then gently pry it out of the casing using the Plastic Cards (also included with your iOpener Kit).
      • Be very careful when prying the battery out of the casing, as you might accidentally puncture it.
      Ask FixBot
      • Use the iOpener to heat up the edges of the old display, then gently pry it up using the Suction Cup and the Opening Picks (both included with your iOpener Kit) and remove it.
      • If the glue on your display is already loose, you can skip this step.
      Ask FixBot
      • Use the Tweezers (included with your iOpener Kit) to remove the adhesive residues created by the display adhesive. To help loosen the residue, you can use a bit of isopropyl alcohol on a cotton swab.
      • At this point, you can also clean the adhesive residues created by the back glass adhesive.
      Ask FixBot
      • Apply the T-7000 adhesive to the edges.
      • Insert the new display and connect the ribbon cable to the motherboard.
      • Make sure that you are feeding the ribbon cable of the display through the small hole.
      • Use the clamps to secure the screen in place.
      • You will have to wait around 12 hours to let the adhesive properly secure the display.
      Ask FixBot
      • After the T-7000 adhesive fully hardens and secures the display in place, reinsert the battery.
      • If replacing the battery, you are advised to dispose of the old battery at a dedicated tech recycling center.
      • At this point, you can now reconnect the cameras to the motherboard.
      Ask FixBot
      • Place the metal shield in its designated place and fasten the screws.
      Ask FixBot
      • Reinsert the back glass.
      • If replacing the back glass, you are advised to properly dispose of it.
      • Use the clamps to secure the back glass in place.
      • You will have to wait another 12 hours to let the adhesive properly secure the back glass.
      Ask FixBot
You’ve successfully replaced the display on your Huawei P smart Pro! Taking the time to carefully follow each step ensures your device is restored to full functionality and looks as good as new. Remember to test all features before final assembly to catch any issues early.
Regular maintenance and cautious handling will help prolong your phone’s lifespan. If you encounter any difficulties or have questions, don’t hesitate to reach out to the repair community for support.
Great job on completing this repair—your phone is ready to tackle whatever comes next!
Author
with
Tiberiu S.
208 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 92
All Time: 512
