Huawei Mate 8 Battery prereq
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Huawei Mate 8 Battery prereq, Daughterboard interconnect cable: step 1, image 1 of 3 Huawei Mate 8 Battery prereq, Daughterboard interconnect cable: step 1, image 2 of 3 Huawei Mate 8 Battery prereq, Daughterboard interconnect cable: step 1, image 3 of 3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  2. Huawei Mate 8 Battery prereq: step 2, image 1 of 3 Huawei Mate 8 Battery prereq: step 2, image 2 of 3 Huawei Mate 8 Battery prereq: step 2, image 3 of 3
    • Use the flat end of a spudger to disconnect the daughterboard interconnect, display, and battery cables.
  3. Huawei Mate 8 Battery prereq: step 3, image 1 of 2 Huawei Mate 8 Battery prereq: step 3, image 2 of 2
    • Use tweezers to disconnect the antenna cable that runs over the metal shield. It makes the removal of the metal plate way easier.
    • Remove the metal plate.
  4. Huawei Mate 8 Battery prereq: step 4, image 1 of 1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
Dominik Schnabelrauch
207,198 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 88
