Shop the Holiday Gift Guide
How to Repair a Broken Hook and Loop Strap
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
47
Past 30 Days:
198
All Time:
3,029
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If you've noticed a falling-apart velcro strap on your favorite pair of shoes, don't worry – repairing the seam on a velcro strap is a simple process and doesn't require advanced sewing skills. We will walk you through the steps, ensuring the velcro on your shoes are just as new after a few minutes.
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
    1. How to Repair a Broken Hook and Loop Strap, Identify the defect: step 1, image 1 of 3 How to Repair a Broken Hook and Loop Strap, Identify the defect: step 1, image 2 of 3 How to Repair a Broken Hook and Loop Strap, Identify the defect: step 1, image 3 of 3
      • Here we can clearly see the defect: The stitching of the velcro strap is broken.
      • The upper material and the velcro strap are not properly attached anymore.
      • We can repair the strap by using a sewing machine.
      Ask FixBot
    2. How to Repair a Broken Hook and Loop Strap, Prepare the stitching: step 2, image 1 of 2 How to Repair a Broken Hook and Loop Strap, Prepare the stitching: step 2, image 2 of 2
      • Check the original seam in terms of thread color, stitching length and pattern.
      • For better results, try to use similar thread color and stitching technique as with the original seam.
      • After having set-up the sewing machine, place the strap onto the needle thread plate.
      • Make sure you can easily move the strap through the needle feed.
      Ask FixBot
    3. How to Repair a Broken Hook and Loop Strap, Start the stitching: step 3, image 1 of 2 How to Repair a Broken Hook and Loop Strap, Start the stitching: step 3, image 2 of 2
      • Start the stitching a few mm before the damaged thread to secure it.
      • Use back stitching to prevent the seam from opening.
      • Tip: In-between the stitching, check carefully whether the edges are correctly overlapping.
      Ask FixBot
    4. How to Repair a Broken Hook and Loop Strap, Stitching phase: step 4, image 1 of 3 How to Repair a Broken Hook and Loop Strap, Stitching phase: step 4, image 2 of 3 How to Repair a Broken Hook and Loop Strap, Stitching phase: step 4, image 3 of 3
      • Follow the original seam to cover the stitching holes and ensure a close-to-original look.
      Ask FixBot
    5. How to Repair a Broken Hook and Loop Strap, Finish the stitching: step 5, image 1 of 2 How to Repair a Broken Hook and Loop Strap, Finish the stitching: step 5, image 2 of 2
      • Use a back stitching to prevent the seam from opening.
      • Remove the strap carefully from the sewing machine and cut off all the excess seams.
      Ask FixBot
    6. How to Repair a Broken Hook and Loop Strap, Finished and ready!: step 6, image 1 of 3 How to Repair a Broken Hook and Loop Strap, Finished and ready!: step 6, image 2 of 3 How to Repair a Broken Hook and Loop Strap, Finished and ready!: step 6, image 3 of 3
      • 🛠️🏆👏 Congratulations! The repair of the strap is complete, and you're ready to go!
      Ask FixBot
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Author
with
Ben Blischke
10,548 Reputation
68 Guides authored
INTERSPORT Member of INTERSPORT
Community
25 Members
828 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 47
Past 30 Days: 198
All Time: 3,029
