How to verify and repair Mac OS X Disk Permissions
  1. How to verify and repair Mac OS X Disk Permissions, How to verify and repair Mac OS X Disk Permissions: step 1, image 1 of 2 How to verify and repair Mac OS X Disk Permissions, How to verify and repair Mac OS X Disk Permissions: step 1, image 2 of 2
    • You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
    • Or you can take the shortcut and use Spotlight!
  2. How to verify and repair Mac OS X Disk Permissions: step 2, image 1 of 2 How to verify and repair Mac OS X Disk Permissions: step 2, image 2 of 2
    • Once opened, you should be presented with a window that looks like this.
    • You will want to select the name of your Mac OS X Startup disk in the left column.
    • After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
    • The First Aid heading is what you will want to be under.
    • Click on the Verify Disk Permissions, starting the process.
  3. How to verify and repair Mac OS X Disk Permissions: step 3, image 1 of 2 How to verify and repair Mac OS X Disk Permissions: step 3, image 2 of 2
    • This usually will take anywhere from 3 minutes to 15 minutes. The best thing to do is to wait.
    • As time progresses, you will see information pop up in the window highlighted.
    • This is good, it means that it is seeing the problems that may be keeping your computer from running well.
  4. How to verify and repair Mac OS X Disk Permissions: step 4, image 1 of 2 How to verify and repair Mac OS X Disk Permissions: step 4, image 2 of 2
    • After verifying the disk permissions, go ahead and select repair disk permissions to start that process.
    • During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
Congrats! You successfully repaired your disk permissions!
54 other people completed this guide.
Mike
14,455 Reputation
3 Guides authored
2 Guide Comments
verify disk does not come up after I enter fix and the procedure stops, I am running high sierra 10.13.6, Help please
gene kaz - Reply
Did anyone help you? I'm running through the same issues?
Marco Saavedra -
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 177
All Time: 16,496
