How to fix a Detached Backpack Strap
Views: 1.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
39
Past 30 Days:
205
All Time:
1,098
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your backpack strap has come off, don’t worry. It’s a common issue and usually easy to fix. Whether it tore off completely or slipped out of its stitching, we will show you simple ways to reattach and strengthen it so your backpack is ready for your next adventure!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
    1. How to fix a Detached Backpack Strap, Prepare the area for the repair: step 1, image 1 of 3 How to fix a Detached Backpack Strap, Prepare the area for the repair: step 1, image 2 of 3 How to fix a Detached Backpack Strap, Prepare the area for the repair: step 1, image 3 of 3
      • Locate the detached strap and gather all the tools needed for the fix.
      • Note: In this example, the strap is not fully detached. However, if the backpack is worn extensively, the seam could break and the strap could come off completely.
      Ask FixBot
    2. How to fix a Detached Backpack Strap, Clean the area: step 2, image 1 of 3 How to fix a Detached Backpack Strap, Clean the area: step 2, image 2 of 3 How to fix a Detached Backpack Strap, Clean the area: step 2, image 3 of 3
      • Remove the strap from the seam.
      • Use a pair of scissors and a seam ripper to cut the strap off and remove any loose threads.
      • Tip: You may need to remove both internal and external stitches. In this example, an internal binding (yellow arrow) also needed to be cut.
      Ask FixBot
    3. How to fix a Detached Backpack Strap, Remove the strap: step 3, image 1 of 2 How to fix a Detached Backpack Strap, Remove the strap: step 3, image 2 of 2
      • Once the area has been cleaned, completely remove the strap from the seam in preparation for the next step.
      Ask FixBot
    4. How to fix a Detached Backpack Strap, Fix the strap in place: step 4, image 1 of 3 How to fix a Detached Backpack Strap, Fix the strap in place: step 4, image 2 of 3 How to fix a Detached Backpack Strap, Fix the strap in place: step 4, image 3 of 3
      • Reintroduce the strap into the seam and secure it in place with sewing pins.
      Ask FixBot
    5. How to fix a Detached Backpack Strap, Start sewing: step 5, image 1 of 3 How to fix a Detached Backpack Strap, Start sewing: step 5, image 2 of 3 How to fix a Detached Backpack Strap, Start sewing: step 5, image 3 of 3
      • Use a sewing machine to stitch the strap in place.
      • Make sure the needle is positioned on the side and not in the middle (red arrow).
      • After stitching, make sure that the seam is done back and forth and that it is fully fixed.
      Ask FixBot
    6. How to fix a Detached Backpack Strap, Reinforce the stitch: step 6, image 1 of 3 How to fix a Detached Backpack Strap, Reinforce the stitch: step 6, image 2 of 3 How to fix a Detached Backpack Strap, Reinforce the stitch: step 6, image 3 of 3
      • Although a sewing machine is preferred, if the fabric is too thick, the stitching can be reinforced by hand.
      • Note: In this example, we use a combination of hand stitching and a sewing machine.
      Ask FixBot
    7. How to fix a Detached Backpack Strap, Clean the area: step 7, image 1 of 3 How to fix a Detached Backpack Strap, Clean the area: step 7, image 2 of 3 How to fix a Detached Backpack Strap, Clean the area: step 7, image 3 of 3
      • Use a pair of scissors to clean the area and remove any loose threads.
      Ask FixBot
    8. How to fix a Detached Backpack Strap, Finished and ready!: step 8, image 1 of 3 How to fix a Detached Backpack Strap, Finished and ready!: step 8, image 2 of 3 How to fix a Detached Backpack Strap, Finished and ready!: step 8, image 3 of 3
      • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
      Ask FixBot
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10,548 Reputation
68 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 205
All Time: 1,098
