Introduction
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  3. Your camera should look something like this.
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  4. Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  5. All cleaned up!
    • All cleaned up!
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 other people completed this guide.
Zachary Phillips
205 Reputation
5 Guides authored
Cal Poly, Team 25-26, Garner Spring 2011 Member of Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Members
7 Guides authored
One Comment
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 58
All Time: 11,918
