How to clean Microtek ScanMaker 5900 glass
  1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: step 1, image 1 of 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: step 1, image 2 of 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: step 1, image 3 of 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: step 2, image 1 of 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: step 2, image 2 of 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: step 2, image 3 of 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: step 3, image 1 of 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: step 3, image 2 of 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: step 3, image 3 of 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: step 4, image 1 of 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: step 4, image 2 of 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: step 4, image 3 of 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: step 5, image 1 of 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: step 5, image 2 of 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: step 5, image 3 of 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. How to clean Microtek ScanMaker 5900 glass, How to clean Microtek ScanMaker 5900 glass: step 6, image 1 of 1
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
Steven Shaginyan
39 Reputation
4 Guides authored
Cal Poly, Team 6-9, Regan Fall 2011 Member of Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Members
22 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 9
All Time: 2,564
