How to Use the VoltClip to Debond iPhone Battery Adhesive
  1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Assemble the VoltClip: step 1, image 1 of 2 How to Use the VoltClip to Debond iPhone Battery Adhesive, Assemble the VoltClip: step 1, image 2 of 2
    • Plug the VoltClip's barrel connector into the USB-C elbow.
    • Don't connect the VoltClip to a power source just yet. The loose alligator clips may accidentally touch each other and cause an electrical short.
  2. How to Use the VoltClip to Debond iPhone Battery Adhesive, Peel up the silver tab: step 2, image 1 of 2 How to Use the VoltClip to Debond iPhone Battery Adhesive, Peel up the silver tab: step 2, image 2 of 2
    • Use a clean fingernail or an opening pick to peel up the silver tab at the bottom edge of the battery.
  3. How to Use the VoltClip to Debond iPhone Battery Adhesive, Attach the alligator clips: step 3, image 1 of 2 How to Use the VoltClip to Debond iPhone Battery Adhesive, Attach the alligator clips: step 3, image 2 of 2
    • Attach the red alligator clip to the silver tab on the battery.
  4. How to Use the VoltClip to Debond iPhone Battery Adhesive: step 4, image 1 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive: step 4, image 2 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive: step 4, image 3 of 3
    • Attach the black alligator clip to the grounding screw.
  5. How to Use the VoltClip to Debond iPhone Battery Adhesive, Connect power to the VoltClip: step 5, image 1 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive, Connect power to the VoltClip: step 5, image 2 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive, Connect power to the VoltClip: step 5, image 3 of 3
    • Make sure the red alligator clip isn't touching any stray metallic surfaces.
    • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
  6. How to Use the VoltClip to Debond iPhone Battery Adhesive, Disconnect the VoltClip: step 6, image 1 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive, Disconnect the VoltClip: step 6, image 2 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive, Disconnect the VoltClip: step 6, image 3 of 3
    • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
  7. How to Use the VoltClip to Debond iPhone Battery Adhesive, Remove the battery: step 7, image 1 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive, Remove the battery: step 7, image 2 of 3 How to Use the VoltClip to Debond iPhone Battery Adhesive, Remove the battery: step 7, image 3 of 3
    • Your adhesive should be fully loosened at this point. If your battery doesn't budge during the step, reconnect the VoltClip for an additional minute and try again.
    • Grip the silver tab and lift the battery out of the frame.
    • Alternatively, you can use a suction handle to pull the battery out. If the battery doesn't come out easily, don't force it—reconnect the VoltClip for one minute.
For more iPhone guides, click here.
4 other people completed this guide.
Arthur Shi
313,851 Reputation
729 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 56
Past 30 Days: 284
All Time: 9,822
