Introduction
All of the internal wiring needs to be connected. Soldering wires to the Faceplate ensures that your microphone will function properly.
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
Bend the wire around the contact point.
The yellow wire goes to the contact above the red lettering.
The green wire goes on the contact point with a “+” next to it.
In one hand, hold the solder. In the other hold your soldering iron.
Touch both the soldering iron and the solder to the contact point. The solder should melt and forge a connection to the face plate.
First, remove the solder and then the soldering iron from the contact point.
Let the wire cool for 30 seconds or so.
