Repairing Shure SM58 Faceplate Wire
  1. Repairing Shure SM58 Faceplate Wire, Collar: step 1, image 1 of 3 Repairing Shure SM58 Faceplate Wire, Collar: step 1, image 2 of 3 Repairing Shure SM58 Faceplate Wire, Collar: step 1, image 3 of 3
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. Repairing Shure SM58 Faceplate Wire, Faceplate Wire: step 2, image 1 of 2 Repairing Shure SM58 Faceplate Wire, Faceplate Wire: step 2, image 2 of 2
    • Plug the soldering iron in and let it heat up for five minutes.
  3. Repairing Shure SM58 Faceplate Wire: step 3, image 1 of 1
  4. Repairing Shure SM58 Faceplate Wire: step 4, image 1 of 1
    • Bend the wire around the contact point.
    • The yellow wire goes to the contact above the red lettering.
    • The green wire goes on the contact point with a “+” next to it.
  5. Repairing Shure SM58 Faceplate Wire: step 5, image 1 of 1
    • In one hand, hold the solder. In the other hold your soldering iron.
    • Touch both the soldering iron and the solder to the contact point. The solder should melt and forge a connection to the face plate.
  6. Repairing Shure SM58 Faceplate Wire: step 6, image 1 of 1
    • First, remove the solder and then the soldering iron from the contact point.
    • If you remove the soldering iron first, the solder may become stuck to the contact point.
    • Let the wire cool for 30 seconds or so.
  7. Repairing Shure SM58 Faceplate Wire: step 7, image 1 of 1
    • If your wire is not completely connected, repeat steps 2-5 until the wire is reconnected.
nat coll
642 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
20 Guides authored
Past 24 Hours: 9
Past 7 Days: 75
Past 30 Days: 266
All Time: 31,599
