How to Restore or Apply an Oleophobic Coating
  1. How to Restore or Apply an Oleophobic Coating, Clean the surface: step 1, image 1 of 2 How to Restore or Apply an Oleophobic Coating, Clean the surface: step 1, image 2 of 2
    • Use isopropyl alcohol to thoroughly clean the surface you are planning to apply the coating to.
    • Wipe the screen dry with a clean microfiber cloth.
  2. How to Restore or Apply an Oleophobic Coating, Prepare a wiping finger: step 2, image 1 of 3 How to Restore or Apply an Oleophobic Coating, Prepare a wiping finger: step 2, image 2 of 3 How to Restore or Apply an Oleophobic Coating, Prepare a wiping finger: step 2, image 3 of 3
    • Read the next three steps before you attempt the procedure. The oleophobic coating's liquid solvent evaporates very quickly when applied, so you'll need to work quickly.
    • Wrap one finger in a bit of plastic. You can use a sandwich bag or some plastic wrap.
    • You will use this covered finger to rub the coating liquid onto the screen. This will prevent your finger from absorbing the liquid.
  3. How to Restore or Apply an Oleophobic Coating, Apply the coating to the surface: step 3, image 1 of 3 How to Restore or Apply an Oleophobic Coating, Apply the coating to the surface: step 3, image 2 of 3 How to Restore or Apply an Oleophobic Coating, Apply the coating to the surface: step 3, image 3 of 3
    • Apply 10-15 drops of the oleophobic coating liquid onto the surface.
    • If you are coating a large surface such as a large phone or tablet, apply ten drops to a portion of the screen, and work on one portion at a time.
  4. How to Restore or Apply an Oleophobic Coating, Distribute the coating: step 4, image 1 of 3 How to Restore or Apply an Oleophobic Coating, Distribute the coating: step 4, image 2 of 3 How to Restore or Apply an Oleophobic Coating, Distribute the coating: step 4, image 3 of 3
    • Wipe your plastic-covered finger over the surface with quick, light swipes until the liquid evaporates.
    • You don't need to rub very hard—you're just spreading out the coating molecules onto the surface before the solvent evaporates.
    • If you applied the liquid to only a portion of the surface, repeat the liquid application and rubbing procedure to the remaining surface.
  5. How to Restore or Apply an Oleophobic Coating, Give the coating time to set: step 5, image 1 of 1
    • Do not touch the surface for 8-12 hours in order to allow the coating to bond to the surface.
    • For best results, apply the coating before bedtime, so it has all night to bond.
    • Afterward, you can wipe off any residue remaining on the touch screen with a clean microfiber cloth.
    • Repeat this process 2-3 times to fully maximize the oleophobic coating performance and film durability.
Arthur Shi
252,816 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
Past 24 Hours: 171
Past 7 Days: 1,071
Past 30 Days: 4,760
All Time: 567,795
