Introduction
This guide will show you how to get to the LEDs and how to inspect the circuit board. If there is a faulty connection or a loose wire, this guide shows displays a quick solution.
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
Remove the screws from the four corners of the circuit board.
Remove the circuit board from the top cover.
Shown is the top side of the printed circuit board that contains the LEDs.
Inspect the PCB for any faulty connections or loose components.
Make sure the wires on the side of the board are properly connected.
If the wires have are not connected properly, res-older them to the board.
