Repairing the LEDs
  1. Repairing the LEDs, PCB (Printed Circuit Board): step 1, image 1 of 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Repairing the LEDs: step 2, image 1 of 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Repairing the LEDs: step 3, image 1 of 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Repairing the LEDs: step 4, image 1 of 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Repairing the LEDs: step 5, image 1 of 2 Repairing the LEDs: step 5, image 2 of 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Repairing the LEDs, LEDs: step 6, image 1 of 1
    • The picture reveals the top side of the printed circuit board that contains the LEDs.
    • Inspect the PCB for any faulty connections or loose components.
  7. Repairing the LEDs: step 7, image 1 of 3 Repairing the LEDs: step 7, image 2 of 3 Repairing the LEDs: step 7, image 3 of 3
    • Make sure the wires on the side of the board are properly connected.
    • If the wires have are not connected properly, res-older them to the board.
Queena Phung
114 Reputation
3 Guides authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 58
All Time: 7,889
