Introduction
This fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
Loosen the 4 phillips screws around the rim and remove the front of the cage
Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
