How to Repair a Massey High Velocity Portable Fan
  1. How to Repair a Massey High Velocity Portable Fan, How to Repair a Massey High Velocity Portable Fan: step 1, image 1 of 2 How to Repair a Massey High Velocity Portable Fan, How to Repair a Massey High Velocity Portable Fan: step 1, image 2 of 2
    • Unplug the power cord before beginning.
    • Loosen the 4 phillips screws around the rim and remove the front of the cage
  2. How to Repair a Massey High Velocity Portable Fan: step 2, image 1 of 1
    • Remove the fan blade by loosening the screw on the shaft while pulling up.
    • The screw does not need to be fully removed before the blade will slide free.
  3. How to Repair a Massey High Velocity Portable Fan: step 3, image 1 of 1
    • Remove the wiring cover located above the fan motor.
    • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
  4. How to Repair a Massey High Velocity Portable Fan: step 4, image 1 of 1
    • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
  5. How to Repair a Massey High Velocity Portable Fan: step 5, image 1 of 1
    • Remove the final 2 screws holding the mounting plate to the cage.
  6. How to Repair a Massey High Velocity Portable Fan: step 6, image 1 of 1
    • Carefully pass the motor through the opening at the back of the cage.
  7. How to Repair a Massey High Velocity Portable Fan: step 7, image 1 of 2 How to Repair a Massey High Velocity Portable Fan: step 7, image 2 of 2
    • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
    • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
    • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
  8. How to Repair a Massey High Velocity Portable Fan: step 8, image 1 of 2 How to Repair a Massey High Velocity Portable Fan: step 8, image 2 of 2
    • Clean and lubricate the magnet shaft and mounting brackets
    • Any medium or low viscosity lubricant will do.
Isaac MacMillan
206 Reputation
1 Guide authored
Past 24 Hours: 13
Past 7 Days: 71
Past 30 Days: 388
All Time: 17,696
