How to Open Your Logitech M170 Wireless Mouse
    1. How to Open Your Logitech M170 Wireless Mouse, Power off your mouse: step 1, image 1 of 1
      • Before starting, slide the power switch on the bottom of your mouse to the left, so it's in the OFF position.
      Ask FixBot
    2. How to Open Your Logitech M170 Wireless Mouse, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech M170 Wireless Mouse, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech M170 Wireless Mouse, Remove the battery cover: step 2, image 3 of 3
      • Press down on the battery cover and slide it away from the mouse to remove it.
      Ask FixBot
    3. How to Open Your Logitech M170 Wireless Mouse, Remove the battery: step 3, image 1 of 3 How to Open Your Logitech M170 Wireless Mouse, Remove the battery: step 3, image 2 of 3 How to Open Your Logitech M170 Wireless Mouse, Remove the battery: step 3, image 3 of 3
      • Use your fingers to lift the end of the battery and slide it out of its recess.
      • During reassembly, slide the battery in negative (-) end first, as shown on the engraving in the recess.
      Ask FixBot
    1. How to Open Your Logitech M170 Wireless Mouse, Clip information: step 4, image 1 of 3 How to Open Your Logitech M170 Wireless Mouse, Clip information: step 4, image 2 of 3 How to Open Your Logitech M170 Wireless Mouse, Clip information: step 4, image 3 of 3
      • The top half of the mouse is held in place with plastic clips. Releasing is very tricky. Note the following before releasing the clips:
      • The clips can easily break if too much force is applied. Take your time to avoid damage.
      • There are five clips located around the perimeter of the top shell that slide into the bottom shell.
      • The clips can be accessed through cutouts on the bottom of the mouse.
      Ask FixBot
    2. How to Open Your Logitech M170 Wireless Mouse, Release the clips: step 5, image 1 of 3 How to Open Your Logitech M170 Wireless Mouse, Release the clips: step 5, image 2 of 3 How to Open Your Logitech M170 Wireless Mouse, Release the clips: step 5, image 3 of 3
      • Insert the flat edge of an opening pick under the outer edge of the left click button.
      • Tilt the pick so it's flat and slide it towards the rear of the mouse to release the back left clip—this will also release the rear clip.
      • You should feel and hear the clip release. If you don't, remove the pick and try again.
      • Leave the pick inserted near the rear of the shell for the next step.
      Ask FixBot
    3. How to Open Your Logitech M170 Wireless Mouse: step 6, image 1 of 2 How to Open Your Logitech M170 Wireless Mouse: step 6, image 2 of 2
      • Slide the pick up the right side to release the back right clip.
      • If you're having a very hard time releasing the clips, you can insert a spudger in the cutouts through the bottom of the mouse and gently push the rear clips outward (away from the mouse) and try again.
      Ask FixBot
    4. How to Open Your Logitech M170 Wireless Mouse, Remove the top half: step 7, image 1 of 3 How to Open Your Logitech M170 Wireless Mouse, Remove the top half: step 7, image 2 of 3 How to Open Your Logitech M170 Wireless Mouse, Remove the top half: step 7, image 3 of 3
      • Lift and remove the top half of the mouse.
      • The top half should come away easily. If it doesn't, repeat the previous two steps to ensure the clips are released.
      • During reassembly, slide the hooked clips at the front of the mouse into their grooves before lowering the top half into place. Then, press down firmly around the perimeter to engage the rear clips.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
206,090 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 81
Past 30 Days: 298
All Time: 1,092
