How to Open Your Logitech K295 Keyboard
    1. How to Open Your Logitech K295 Keyboard, Prepare your keyboard for disassembly: step 1, image 1 of 2 How to Open Your Logitech K295 Keyboard, Prepare your keyboard for disassembly: step 1, image 2 of 2
      • Slide the power switch to the OFF position.
      • Flip your keyboard over and lay it down so the edge with the two tilt legs is closest to you.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    2. How to Open Your Logitech K295 Keyboard, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech K295 Keyboard, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech K295 Keyboard, Remove the battery cover: step 2, image 3 of 3
      • Pull the battery cover's center tab in and up to remove the cover.
      Ask FixBot
    3. How to Open Your Logitech K295 Keyboard, Remove the batteries: step 3, image 1 of 3 How to Open Your Logitech K295 Keyboard, Remove the batteries: step 3, image 2 of 3 How to Open Your Logitech K295 Keyboard, Remove the batteries: step 3, image 3 of 3
      • Use your finger to lift the edge of the first battery and remove it.
      • Slide the second battery out of its recess and remove it.
      • During reassembly, slide the AAA batteries in negative (-) end first, as shown in the recess.
      Ask FixBot
    1. How to Open Your Logitech K295 Keyboard, Remove the keyboard screws: step 4, image 1 of 2 How to Open Your Logitech K295 Keyboard, Remove the keyboard screws: step 4, image 2 of 2
      • Use a Phillips screwdriver to remove the fifteen 8.8 mm‑long screws securing the keyboard together.
      Ask FixBot
    2. How to Open Your Logitech K295 Keyboard, Flip your keyboard over: step 5, image 1 of 1
      • Flip your keyboard over so the keys are facing up.
      Ask FixBot
    3. How to Open Your Logitech K295 Keyboard, Insert an opening pick: step 6, image 1 of 3 How to Open Your Logitech K295 Keyboard, Insert an opening pick: step 6, image 2 of 3 How to Open Your Logitech K295 Keyboard, Insert an opening pick: step 6, image 3 of 3
      • Insert the long edge of an opening pick in the seam between the two halves of the keyboard, by the bottom of the left edge.
      • Pry up the top half of the keyboard to release the clip.
      • You should feel and hear a "click" as the clip releases.
      • Leave the pick inserted for the next step.
      Ask FixBot
    4. How to Open Your Logitech K295 Keyboard, Release the clips: step 7, image 1 of 3 How to Open Your Logitech K295 Keyboard, Release the clips: step 7, image 2 of 3 How to Open Your Logitech K295 Keyboard, Release the clips: step 7, image 3 of 3
      • With the pick angled flat to the keyboard, slide it along the left edge to release the clips securing the two halves.
      • You should feel and hear "clicks" as the pick slides along each section. If you don't, the clips didn't release—slide the pick along the section again and pry gently.
      Ask FixBot
    5. How to Open Your Logitech K295 Keyboard: step 8, image 1 of 3 How to Open Your Logitech K295 Keyboard: step 8, image 2 of 3 How to Open Your Logitech K295 Keyboard: step 8, image 3 of 3
      • Continue sliding the pick along the top and right edges until all the clips are released.
      • Don't try to fully separate the two halves yet—you risk damaging the plastic membrane connected to the top half.
      Ask FixBot
    6. How to Open Your Logitech K295 Keyboard, Flip your keyboard over: step 9, image 1 of 1
      • Gently hold the two halves of the keyboard together and flip it over so the bottom is facing up.
      Ask FixBot
    7. How to Open Your Logitech K295 Keyboard, Remove the bottom half: step 10, image 1 of 2 How to Open Your Logitech K295 Keyboard, Remove the bottom half: step 10, image 2 of 2
      • Remove the bottom half of the keyboard.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
197,893 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 48
Past 30 Days: 193
All Time: 831
