How to Install macOS High Sierra
  1. How to Install macOS High Sierra, How to Install macOS High Sierra: step 1, image 1 of 2 How to Install macOS High Sierra, How to Install macOS High Sierra: step 1, image 2 of 2
    • With the device powered off, disconnect any external hard drives and flash drives.
    • Plug in your macOS High Sierra bootable flash drive.
    • Hold down the [option] or [alt] (⌥) key on the keyboard and power on the device.
    • When you see the boot selection screen as shown, release the [option] key.
    • Use either the keyboard's arrow keys or the mouse to select "Install MacOS High Sierra." Press [enter] or click your selection with the mouse.
  2. How to Install macOS High Sierra: step 2, image 1 of 2 How to Install macOS High Sierra: step 2, image 2 of 2
    • Your Mac will begin copying the installation files from the flash drive. This may take up to 30 minutes.
    • Depending on the speed of your flash drive, it may look like progress has frozen, but it should resume if you continue to wait.
    • When prompted, select your language and press [enter], or click the arrow button.
  3. How to Install macOS High Sierra: step 3, image 1 of 2 How to Install macOS High Sierra: step 3, image 2 of 2
    • If you don't need to pre-configure your hard drive, skip to step 5. If you're not sure or if the drive is used, it's a good idea to pre-configure your hard drive.
    • Select "Disk Utility" from the menu and press [enter] or click the continue button.
  4. How to Install macOS High Sierra: step 4, image 1 of 3 How to Install macOS High Sierra: step 4, image 2 of 3 How to Install macOS High Sierra: step 4, image 3 of 3
    • Select your hard drive from the left column in Disk Utility.
    • It is most likely the uninitialized drive.
    • If you have multiple hard drives, make sure you select the correct one as the next step will wipe the selected drive clean.
    • Click the "Erase" button at the top of the window.
    • Choose a name for your drive (you can rename it later). Leave the format as Mac OS Extended (journaled), and the scheme as GUID Partition Map.
    • Click "Erase."
    • When the process completes, click "Done."
    • Exit the Disk Utility by clicking on the red X button on the top left corner of the window.
  5. How to Install macOS High Sierra: step 5, image 1 of 2 How to Install macOS High Sierra: step 5, image 2 of 2
    • Select "Reinstall macOS" from the menu and press [enter] or click "Continue."
  6. How to Install macOS High Sierra: step 6, image 1 of 3 How to Install macOS High Sierra: step 6, image 2 of 3 How to Install macOS High Sierra: step 6, image 3 of 3
    • Read through the license agreement.
    • Click "Agree" to accept the license agreement.
    • Your Mac will now install macOS High Sierra. Be patient and wait for it to complete.
    • Once the install is complete, the device will restart itself.
Arthur Shi
254,547 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 255
Past 7 Days: 1,756
Past 30 Days: 7,859
All Time: 1,820,570
