Introduction
If you're tired of your halogen headlights or fog lights and want to upgrade to something with a better output, try installing an HID Conversion Kit.
Open the hood.
Locate the back of the headlights and remove the bolts holding the headlight housing.
Take out the HID bulb from the plastic shell and remove the circular plastic piece.
Remember not to touch the HID bulb glass!
If you accidentally touch it, you can clean it with some rubbing alcohol.
Insert the HID bulb back into the headlight housing.
Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
Before you mount the ballast, test the HID light to make sure it lights up.
If not, turn the adapter wire 180 degrees.
Mount the HID ballast with zip ties.
