Introduction
Jeans a little too long? No problem. Hem your own jeans for the perfect fit.
This guide will show you how to hem or shorten your jeans while keeping the original hem or cuff, and includes instructions on how to restore the original length at the end, which is perfect for growing kids.
You'll need a sewing machine and some thread that matches the color of your jeans. You'll want to put a heavy-duty or denim needle in your sewing machine before you get started.
Don't know how to use a sewing machine? No sweat. This guide only requires a simple straight stitch—and we've got a guide for that. Check out our Basic Sewing section for more information.
For help with sewing terms, check out our Sewing Glossary.
While wearing your jeans, have a friend help you fold the cuffs of each pant leg to your desired length.
Have your friend safety pin the folded cuff to the pant leg to hold the fold in place.
Measure the length from the cuff of the jeans to the fold. This is the length you want to remove from the jeans.
Unpin the cuff of the jeans.
Add an inch to the measurement you took, and use tailor's chalk to mark this new measurement as a second line one inch above the first line you made.
Continue marking all the way around the pant leg.
Insert a row of straight pins along the marks of your second line, which sits one inch above the amount you want to remove.
Insert pins all the way around the pant leg.
Fold the cuff of the pant leg up to meet the line of pins, matching the edge of the jeans with the row of pins.
Insert a row of pins perpendicular to the bottom of the cuff, catching the fold and holding it in place.
Remove the first horizontal row of pins.
Set up your sewing machine with thread that matches your jeans and a heavy-duty/denim needle.
Insert the pant leg into the sewing machine, sliding the cuff around the arm of the sewing machine.
Align the center of the presser foot (and needle) with the edge of the hem on the jeans.
Lower the presser foot and take a few stitches, keep the line of stitches right at the edge of the hem.
When you come to the first pin, stop sewing.
Without lifting the presser foot, remove the pin.
Continue sewing around the pant leg, at the edge of the hem, stopping to remove pins as you go.
When you come back to where you started sewing, continue sewing, overlapping the first few stitches.
Lift the presser foot and slide the jeans out.
Clip the threads that attach the jeans to the sewing machine.
Unfold the jeans, tucking the fold you just sewed inside the pant leg.
Insert the pant leg back into the sewing machine, right-side out, around the arm of the machine.
Align the presser foot along the edge of the side seam of the pants.
Lower the presser foot and take a couple of stitches.
Use the reverse function on your sewing machine to backstitch a couple of stitches.
Sew along the edge of the hem for about a dozen stitches.
