Community-Contributed Guide
Introduction
Go to step 1 ↓Properly gripping your hiking pole is crucial for stability and comfort on the trails. Whether you’re a seasoned hiker or just starting out, ensuring your hiking pole is in top shape and your grip is secure can make a big difference. We will show you a quick and creative fix that will solve the problem in no time!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
Tools
Find a replacement grip tape to fix your pole.
Note: In this example we used the grip tape for tennis and badminton rackets.
Open the grip tape and look for the diagonal tip of the tape. Set aside the sticker wrap (green arrow). This will be useful for the final part of the repair.
Tip: in order to identify the right tip, put both ends side to side and look for the one that has a "diagonal" shape (orange arrow).
Remove the sticker back (red circle) of the tip and and begin to wrap the tape around the grip.
Make sure you begin at the end of the grip and start to wrap it upwards, keeping it tight at all times.
Continue to wrap the tape around the grip until you reach the end of handle.
Once you have reached the end of the grip, it is time to cut the end of the tip.
Follow the red line to cut it in a "diagonal shape".
Use the sticker wrap that came with the tape to close the new grip and set it in place.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
- Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
- Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
- Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
