PS4 Case Opening Procedure
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. PS4 Case Opening Procedure, Flip over the PS4: step 1, image 1 of 1
      • Flip the PS4 upside-down with the back side facing towards you.
      Ask FixBot
    2. PS4 Case Opening Procedure, Remove the warranty stickers: step 2, image 1 of 3 PS4 Case Opening Procedure, Remove the warranty stickers: step 2, image 2 of 3 PS4 Case Opening Procedure, Remove the warranty stickers: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
      Ask FixBot
    3. PS4 Case Opening Procedure, Remove the plastic screw covers: step 3, image 1 of 2 PS4 Case Opening Procedure, Remove the plastic screw covers: step 3, image 2 of 2
      • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
      Ask FixBot
    4. PS4 Case Opening Procedure, Remove the rear case screws: step 4, image 1 of 2 PS4 Case Opening Procedure, Remove the rear case screws: step 4, image 2 of 2
      • Remove the four 7.2 mm T8 Torx security screws on the back of the PS4.
      Ask FixBot
    5. PS4 Case Opening Procedure, Remove the lower case: step 5, image 1 of 2 PS4 Case Opening Procedure, Remove the lower case: step 5, image 2 of 2
      • Use your thumbs to lift the lower case up and off the PS4.
      • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
      Ask FixBot
    6. PS4 Case Opening Procedure: step 6, image 1 of 2 PS4 Case Opening Procedure: step 6, image 2 of 2
      • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
      • If your connector feels stuck, use a spudger to gently pry the connector out.
      Ask FixBot
Sam Omiotek
100,913 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 830
