Acer Chromebook 11 C733 Battery Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
96
All Time:
2,053
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Background Information
Use this guide to replace your Acer C733 Chromebook’s worn-down battery with a new battery. If your battery is swollen or smoking, take appropriate precautions.
Once the new battery is installed, you will need to bring the device out of storage mode once this guide is completed. You will need to plug the device into a charger and a power source and simply power up the device like normal.
Additional Notes
The C733 Chromebook shares a lot of the same parts that are in the C732 Chromebook, including the battery. This makes a lot of the older parts that are in the C732 salvageable, including the keyboard, trackpad, and screen.
Parts
Tools
    1. Acer Chromebook 11 C733 Battery Replacement, Opening up your device: step 1, image 1 of 2 Acer Chromebook 11 C733 Battery Replacement, Opening up your device: step 1, image 2 of 2
      • Flip the computer over, and using a Phillips #1 screwdriver, remove all 12 bottom cover screws.
      • Once all the screws are removed, place both pointer fingers between the screen hinges and the case and carefully pry the case away from the hinges.
      Ask FixBot
    2. Acer Chromebook 11 C733 Battery Replacement, Remove the ESD tape: step 2, image 1 of 3 Acer Chromebook 11 C733 Battery Replacement, Remove the ESD tape: step 2, image 2 of 3 Acer Chromebook 11 C733 Battery Replacement, Remove the ESD tape: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Once the back cover is removed, you will see that the battery is only held in place with a few pieces of ESD Tape. Using a set of tweezers, or your fingers, carefully peel away the tape from one end.
      • You might need to peel away the tape covering the keyboard cable.
      Ask FixBot
    3. Acer Chromebook 11 C733 Battery Replacement, Disconnect your battery: step 3, image 1 of 1
      • Once the tape is removed, you can use the pointed end of a Spudger or your fingernails and carefully unplug the battery from the logic board.
      Ask FixBot
      • The battery can now be removed.
      • To install the new battery, follow these steps in reverse order.
      Ask FixBot
2 other people completed this guide.
Jacob Mehnert
50,323 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 96
All Time: 2,053
