How to Fix a Broken Seam in a Camping Chair
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
29
Past 30 Days:
121
All Time:
1,520
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Introduction
Even the sturdiest camping chairs can suffer from a broken seam, however fixing it is easier than you might think! We will show you how to repair it, ensuring it’s ready for your next adventure.
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
Tools
    1. How to Fix a Broken Seam in a Camping Chair, Identify the repair area: step 1, image 1 of 3 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: step 1, image 2 of 3 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: step 1, image 3 of 3
      • Locate the broken seam that needs to be fixed.
      Ask FixBot
    2. How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: step 2, image 1 of 3 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: step 2, image 2 of 3 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: step 2, image 3 of 3
      • Use a screwdriver to disassemble the back support and set aside the screws and remaining parts.
      Ask FixBot
    3. How to Fix a Broken Seam in a Camping Chair, Clean the area: step 3, image 1 of 3 How to Fix a Broken Seam in a Camping Chair, Clean the area: step 3, image 2 of 3 How to Fix a Broken Seam in a Camping Chair, Clean the area: step 3, image 3 of 3
      • Using a pair of scissors and a "seam ripper" remove the loose threads.
      Ask FixBot
    4. How to Fix a Broken Seam in a Camping Chair, Start sewing: step 4, image 1 of 3 How to Fix a Broken Seam in a Camping Chair, Start sewing: step 4, image 2 of 3 How to Fix a Broken Seam in a Camping Chair, Start sewing: step 4, image 3 of 3
      • Sew along the "dotted line" following the direction of the red arrow. This is the path where the previous stitch used to be.
      • Note: in this example, the original seam used to have 2 lines of stitches, this is why a second line of stitches is needed to reinforce the area.
      Ask FixBot
    5. How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: step 5, image 1 of 2 How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: step 5, image 2 of 2
      • Using a pair of scissors cut the remaining threads to clean the area.
      Ask FixBot
    6. How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: step 6, image 1 of 3 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: step 6, image 2 of 3 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: step 6, image 3 of 3
      • Start by putting the components back, first the repaired fabric and then the rest of the parts.
      • Tip: make sure the holes in the metal part of the chair match the holes of the fabric (orange circles).
      • Screw back the pieces that were taken on the previous steps.
      Ask FixBot
    7. How to Fix a Broken Seam in a Camping Chair, Finished and ready!: step 7, image 1 of 2 How to Fix a Broken Seam in a Camping Chair, Finished and ready!: step 7, image 2 of 2
      • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
      Ask FixBot
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10,548 Reputation
68 Guides authored
INTERSPORT Member of INTERSPORT
Community
25 Members
828 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 121
All Time: 1,520
