How to Fix Snagged Jeans
  1. How to Fix Snagged Jeans, How to Fix Snagged Jeans: step 1, image 1 of 1
    • Identify the snag that you would like to correct.
  2. How to Fix Snagged Jeans: step 2, image 1 of 2 How to Fix Snagged Jeans: step 2, image 2 of 2
    • Insert the sharp end of your ballpoint needle through the center of the snag.
    • Carefully turn the jeans inside out, while maintaining the placement of the ballpoint needle.
  3. How to Fix Snagged Jeans: step 3, image 1 of 2 How to Fix Snagged Jeans: step 3, image 2 of 2
    • Allow the ballpoint needle to stand vertically. This will happen naturally.
    • Take your No. 18 tapestry needle and gently maneuver all of the loose strings from the snagged denim to the inside of the jeans. You will position your needle to pull the loose strings upward.
    • Make sure there are no loose strings left outside of the jeans.
  4. How to Fix Snagged Jeans: step 4, image 1 of 1
    • String the No. 18 tapestry needle with your thread.
  5. How to Fix Snagged Jeans: step 5, image 1 of 1
    • Tie both ends of the thread that is threaded through the needle to form a knot.
    • The knot should be small and tight
  6. How to Fix Snagged Jeans: step 6, image 1 of 3 How to Fix Snagged Jeans: step 6, image 2 of 3 How to Fix Snagged Jeans: step 6, image 3 of 3
    • Make another knot, this time pull thread slowly and tightly around the snag.
    • Get the knot as close as possible to the surface of the denim jean.
    • Pull the knot as tight as possible.
  7. How to Fix Snagged Jeans: step 7, image 1 of 1
    • Use the scissors to trim the excess thread on both sides.
  8. How to Fix Snagged Jeans: step 8, image 1 of 1
    • Once you've removed the excess thread, take a small amount of fabric adhesive, and rub it against the knot you made to confident the snagged denim. The adhesive will secure the loose strings inside the denim.
    • Apply the adhesive so that the knot is stuck to the surface of the denim.
    • Allow the adhesive at least 20 minutes to dry.
  9. How to Fix Snagged Jeans: step 9, image 1 of 2 How to Fix Snagged Jeans: step 9, image 2 of 2
    • Turn the jeans right side out. The snag is no more!
Samantha Parison
182 Reputation
1 Guide authored
Past 24 Hours: 9
Past 7 Days: 47
Past 30 Days: 234
All Time: 48,947
