How to Fix Broken Crayons
    1. How to Fix Broken Crayons, How to Fix Broken Crayons: step 1, image 1 of 3 How to Fix Broken Crayons, How to Fix Broken Crayons: step 1, image 2 of 3 How to Fix Broken Crayons, How to Fix Broken Crayons: step 1, image 3 of 3
      • Peel off the paper wrapper on all of the crayon pieces.
      Ask FixBot
    2. How to Fix Broken Crayons: step 2, image 1 of 3 How to Fix Broken Crayons: step 2, image 2 of 3 How to Fix Broken Crayons: step 2, image 3 of 3
      • Boil water to 212°F/100°C.
      • A kettle is recommended for more control when pouring.
      Ask FixBot
    3. How to Fix Broken Crayons: step 3, image 1 of 3 How to Fix Broken Crayons: step 3, image 2 of 3 How to Fix Broken Crayons: step 3, image 3 of 3
      • Cut a piece of aluminum foil about 6x2 inches.
      • Fold the 6 inch side of foil in half.
      • Fold up all four sides of the foil to create a thin rectangle, about 1 inch away from the edges.
      Ask FixBot
    4. How to Fix Broken Crayons: step 4, image 1 of 3 How to Fix Broken Crayons: step 4, image 2 of 3 How to Fix Broken Crayons: step 4, image 3 of 3
      • Pinch up the corners of the foil by following the folded creases made in the last step.
      • Repeat this step for all four corners.
      Ask FixBot
    5. How to Fix Broken Crayons: step 5, image 1 of 3 How to Fix Broken Crayons: step 5, image 2 of 3 How to Fix Broken Crayons: step 5, image 3 of 3
      • Insert the broken crayon pieces into the foil mold.
      Ask FixBot
    6. How to Fix Broken Crayons: step 6, image 1 of 3 How to Fix Broken Crayons: step 6, image 2 of 3 How to Fix Broken Crayons: step 6, image 3 of 3
      • Place mold into a heat-safe container.
      • While holding onto the mold, carefully pour in boiling water up to the rim of the mold.
      • Your mold may float in the water or tilt to one side while water is being poured.
      • Wait for the wax to fully melt.
      • Be careful when handling hot materials.
      Ask FixBot
    7. How to Fix Broken Crayons: step 7, image 1 of 3 How to Fix Broken Crayons: step 7, image 2 of 3 How to Fix Broken Crayons: step 7, image 3 of 3
      • Take the mold out of the water once cooled.
      • When wax has moderately hardened, loosen the sides of the foil from the wax.
      • Cut a corner of the foil mold and unwrap the crayon.
      • Leave the newly created crayon in a cool and dry area overnight to fully solidify before use.
      Ask FixBot
Finish Line
Madeline Furtado
166 Reputation
1 Guide authored
UC Davis, Team 2-8, Whithaus Spring 2025 Member of UC Davis, Team 2-8, Whithaus Spring 2025
UCD-WHITHAUS-S25S2G8
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 133
All Time: 999
