How to Disable Auto Boot
  1. How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 1 of 3 How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 2 of 3 How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 3 of 3
    • Power on your Mac and launch Terminal.
    • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
  2. How to Disable Auto Boot: step 2, image 1 of 2 How to Disable Auto Boot: step 2, image 2 of 2
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return].
    • Your [return] key may also be labeled ⏎ or [enter].
    • If you are prompted for an administrative password, type the password and press [return].
    • Your password will not be displayed in Terminal.
  3. How to Disable Auto Boot: step 3, image 1 of 1
    • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • Remember, you must still disconnect the battery before servicing internal components.
  4. How to Disable Auto Boot: step 4, image 1 of 3 How to Disable Auto Boot: step 4, image 2 of 3 How to Disable Auto Boot: step 4, image 3 of 3
    • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
    • sudo nvram AutoBoot=%03
    • Press [return].
    • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
Congrats! You're done.
68 other people completed this guide.
Jeff Suovanen
447,251 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,657 Guides authored
24 Guide Comments
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - Reply
You change the your user/Homefolder name
Ben Capehart -
You do not need to change it for the command to work. But if you really do want to for a different reason, rename your home folder name.
Junaayd Shaikh -
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - Reply
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - Reply
Past 24 Hours: 56
Past 7 Days: 454
Past 30 Days: 2,099
All Time: 199,333
