How to Check Your iPhone's Battery Health
  1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: step 1, image 1 of 1
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. How to Check Your iPhone's Battery Health: step 2, image 1 of 1
    • Scroll down and select Battery.
  3. How to Check Your iPhone's Battery Health: step 3, image 1 of 1
    • Select Battery Health.
  4. How to Check Your iPhone's Battery Health: step 4, image 1 of 1
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new. The lower the percentage is, the older the battery it is (and the greater the chance it will need replaced).
  5. How to Check Your iPhone's Battery Health: step 5, image 1 of 3 How to Check Your iPhone's Battery Health: step 5, image 2 of 3 How to Check Your iPhone's Battery Health: step 5, image 3 of 3
    • Under Peak Performance Capability, it will tell you what your battery's health status is. Normal peak performance is what you're aiming for.
    • When it says your iPhone has experienced an expected shutdown the performance is throttled to prevent further shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery. (click here for other iPhone models)
Josh M
895 Reputation
1 Guide authored
iTech West Palm Beach Member of iTech West Palm Beach
Business
5 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 167
All Time: 10,657
