This teardown is in progress – Reload periodically to see the latest changes!
Video Overview
  1. How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the SIM card tray.: step 1, image 1 of 1
    • Power off the Galaxy S6 Edge Plus and remove the SIM card tray.
  2. How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: step 2, image 1 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: step 2, image 2 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: step 2, image 3 of 3
    • Heat up to soften the adhesive around the back cover.
    • Pull up a gap to insert the prying tool and a poker card.
    • Run the poker card and case opening tool around the edges to separate the back cover.
  3. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the rear housing.: step 3, image 1 of 2 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the rear housing.: step 3, image 2 of 2
    • Undo the 18 screws in the rear housing.
    • Pull up the rear housing from LCD assembly with frame.
  4. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: step 4, image 1 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: step 4, image 2 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: step 4, image 3 of 3
    • Pry up the screen flex connector, battery flex connector, ear speaker flex connector and proximity sensor flex connector.
    • Pry up the motherboard and turn it upside down to release the connector behind.
    • Pry up the connectors on the motherboard to release the front facing and rear facing camera if necessary.
  5. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extreme patient and gentle.): step 5, image 1 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extreme patient and gentle.): step 5, image 2 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extreme patient and gentle.): step 5, image 3 of 3
    • Pry up around the edges of battery as there're two main adhesive sticker underneath.
    • Insert the Spudger to pry up the adhesive.
    • Tear the battery by hands.
  6. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: step 6, image 1 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: step 6, image 2 of 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: step 6, image 3 of 3
    • Pry up to release the proximity sensor module.
    • Pry up to release the ear speaker.
    • Pry up to release the vibrating motor.
  7. How To Tear Down Samsung Galaxy S6 Edge Plus, Galaxy S6 Edge Plus charging port assembly.: step 7, image 1 of 1
    • As stated by the video, the charging port flex ribbon assembly cannot be removed until the front glass is torn down as it’s assembled with the navigator flex in between the glass and LCD.
Mandy
9,518 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 25
All Time: 56,689
