How To Install Universal Fit LED Daytime Running Lights
  1. How To Install Universal Fit LED Daytime Running Lights: step 2, image 1 of 1
    • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
  2. How To Install Universal Fit LED Daytime Running Lights: step 3, image 1 of 1
    • After mounting the bracket, you can lock the LED daytime running light on the bracket.
  3. How To Install Universal Fit LED Daytime Running Lights: step 4, image 1 of 2 How To Install Universal Fit LED Daytime Running Lights: step 4, image 2 of 2
    • Connect the wires and route the wires up and near the fuse box.
    • Use zip ties to tie the wire along the bumper.
  4. How To Install Universal Fit LED Daytime Running Lights: step 5, image 1 of 2 How To Install Universal Fit LED Daytime Running Lights: step 5, image 2 of 2
    • Find the ACC in your fuse box and tap the red wire there.
    • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
    • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
  5. How To Install Universal Fit LED Daytime Running Lights: step 6, image 1 of 1
    • Tap the black wire to battery negative.
  6. How To Install Universal Fit LED Daytime Running Lights: step 7, image 1 of 3 How To Install Universal Fit LED Daytime Running Lights: step 7, image 2 of 3 How To Install Universal Fit LED Daytime Running Lights: step 7, image 3 of 3
    • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
Eric Wu
3,357 Reputation
23 Guides authored
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 115
All Time: 93,311
