How to Replace a Backpack Buckle (without sewing)
  1. How to Replace a Backpack Buckle (without sewing), Identify the repair area: step 1, image 1 of 2 How to Replace a Backpack Buckle (without sewing), Identify the repair area: step 1, image 2 of 2
    • Locate the buckle that needs to be replaced.
    • Note: For this simple solution we are using strap with a single fold and stitch (red circle). For straps with double stitching, additional steps would be needed to unstitch the buckle and then restitch it once it is finished.
  2. How to Replace a Backpack Buckle (without sewing), Remove the existing buckle: step 2, image 1 of 3 How to Replace a Backpack Buckle (without sewing), Remove the existing buckle: step 2, image 2 of 3 How to Replace a Backpack Buckle (without sewing), Remove the existing buckle: step 2, image 3 of 3
    • Following the yellow arrows, push the strap out of the buckle.
    • Keep pushing the strap and gently slide the last bit following the direction of the red arrows.
    • Keep going forward in the direction of the green arrow until the buckle is out of the strap.
  3. How to Replace a Backpack Buckle (without sewing), Insert the new buckle: step 3, image 1 of 3 How to Replace a Backpack Buckle (without sewing), Insert the new buckle: step 3, image 2 of 3 How to Replace a Backpack Buckle (without sewing), Insert the new buckle: step 3, image 3 of 3
    • Repeat the previous step in reverse. Start by introducing the buckle into the strap and following the direction of the green arrows.
    • Keep introducing the buckle following the direction of the yellow arrows.
    • When the strap has passed on both parts of the buckle, pull the tip of the strap in the direction of the red arrows.
  4. How to Replace a Backpack Buckle (without sewing), Tight the buckle: step 4, image 1 of 3 How to Replace a Backpack Buckle (without sewing), Tight the buckle: step 4, image 2 of 3 How to Replace a Backpack Buckle (without sewing), Tight the buckle: step 4, image 3 of 3
    • Pull the strap in the direction of the red arrow to tighten it up.
    • Introduce the strap inside the "strap keeper" and then verify that the new buckle fits its counterpart. If it doesn't, you will need to repeat the previous steps to replace it as well.
    • Tip: if you need help replacing the "strap keeper", check this guide.
  5. How to Replace a Backpack Buckle (without sewing), Finished and ready!: step 5, image 1 of 3 How to Replace a Backpack Buckle (without sewing), Finished and ready!: step 5, image 2 of 3 How to Replace a Backpack Buckle (without sewing), Finished and ready!: step 5, image 3 of 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10,230 Reputation
66 Guides authored
INTERSPORT Member of INTERSPORT
Community
25 Members
169 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 207
All Time: 2,388
