How to Perform a Battery Cycle Reset
  1. How to Perform a Battery Cycle Reset, Download the app: step 1, image 1 of 3 How to Perform a Battery Cycle Reset, Download the app: step 1, image 2 of 3 How to Perform a Battery Cycle Reset, Download the app: step 1, image 3 of 3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Perform a Battery Cycle Reset, Install the app: step 2, image 1 of 2 How to Perform a Battery Cycle Reset, Install the app: step 2, image 2 of 2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Perform a Battery Cycle Reset, Rename the app: step 3, image 1 of 3 How to Perform a Battery Cycle Reset, Rename the app: step 3, image 2 of 3 How to Perform a Battery Cycle Reset, Rename the app: step 3, image 3 of 3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: step 4, image 1 of 3 How to Perform a Battery Cycle Reset: step 4, image 2 of 3 How to Perform a Battery Cycle Reset: step 4, image 3 of 3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: step 5, image 1 of 2 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: step 5, image 2 of 2
    • Select the Galaxy Cal app.
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: step 6, image 1 of 1
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: step 7, image 1 of 2 How to Perform a Battery Cycle Reset, Select the procedure: step 7, image 2 of 2
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: step 8, image 1 of 3 How to Perform a Battery Cycle Reset: step 8, image 2 of 3 How to Perform a Battery Cycle Reset: step 8, image 3 of 3
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
Finish Line
16 other people completed this guide.
Alex Diaz-Kokaisl
214,551 Reputation
1,044 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,764 Guides authored
47 Guide Comments
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - Reply
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
Past 24 Hours: 117
Past 7 Days: 630
Past 30 Days: 3,009
All Time: 108,453
