How to Factory Reset an AirTag
  1. How to Factory Reset an AirTag, How to Factory Reset an AirTag: step 1, image 1 of 1
    • Using one finger press, down on the back of the AirTag.
  2. How to Factory Reset an AirTag: step 2, image 1 of 1
    • Twist the back cover counterclockwise.
    • Lift and remove the cover.
  3. How to Factory Reset an AirTag: step 3, image 1 of 1
    • Remove the battery using an index finger and thumb.
    • If you need to replace the battery, do so now. The battery type is a CR2032
  4. How to Factory Reset an AirTag: step 4, image 1 of 1
    • Place the battery back into the AirTag facing upwards.
    • Press down on the battery with light pressure until you hear a chime.
    • This ringing indicates that the battery is connected.
    • If you do not hear a ringing tone, your battery might need to be replaced.
  5. How to Factory Reset an AirTag: step 5, image 1 of 3 How to Factory Reset an AirTag: step 5, image 2 of 3 How to Factory Reset an AirTag: step 5, image 3 of 3
    • When the chime finishes playing, repeat Step 4 five times by removing the battery, replacing it, and pressing down on the battery until you hear a chime.
    • On the fifth time you will hear a different chime as compared to the four previous times.
  6. How to Factory Reset an AirTag: step 6, image 1 of 2 How to Factory Reset an AirTag: step 6, image 2 of 2
    • Once the fifth chime is heard the Air Tag has been reset and is ready to be paired.
16 other people completed this guide.
Daniel Barajas
525 Reputation
1 Guide authored
5 Guide Comments
Thank you for sharing this information. I’m investigating this product prior to purchasing.
DonManion - Reply
I believe that using the "Remove" command in Find My app (Items) will reset the AirTag for another person to use. It disconnects it from the Apple ID used to register it. Have tested this.
Of course, if the AirTag is malfunctioning, this battery method should suffice to fully reset it. You will probably want to remove it from the Find My app anyway so new registration can proceed. (I have not tested performing this hard reset and then pairing with my ID while it was still registered.)
David Spalding - Reply
I try and my grandson and both failed to take the tags apart following the instructions where I get them changed?
Jajue - Reply
I've got the same problem. Anyone got a solution?
Peter T -
I use a jar opener pad that gives a bit more friction than my finger could. It works every time for me.
Paul Lugg - Reply
Past 24 Hours: 11
Past 7 Days: 152
Past 30 Days: 739
All Time: 19,182
