Hover-1 XLS LCD Screen Replacement
    1. Hover-1 XLS LCD Screen Replacement, Ignition: step 1, image 1 of 1
      • Remove the six 16mm #3 Hex head screws located on the front panel.
      • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
      Ask FixBot
    2. Hover-1 XLS LCD Screen Replacement: step 2, image 1 of 3 Hover-1 XLS LCD Screen Replacement: step 2, image 2 of 3 Hover-1 XLS LCD Screen Replacement: step 2, image 3 of 3
      • Grab the front panel and gently lift it up to the side.
      • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
      Ask FixBot
    3. Hover-1 XLS LCD Screen Replacement: step 3, image 1 of 1
      • Remove the two, 19 mm Phillips #2 screws holding the ignition.
      • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
      Ask FixBot
    1. Hover-1 XLS LCD Screen Replacement, LCD Screen: step 4, image 1 of 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: step 4, image 2 of 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: step 4, image 3 of 3
      • Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
      • Remove the casing on the LCD.
      Ask FixBot
    2. Hover-1 XLS LCD Screen Replacement: step 5, image 1 of 3 Hover-1 XLS LCD Screen Replacement: step 5, image 2 of 3 Hover-1 XLS LCD Screen Replacement: step 5, image 3 of 3
      • Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
      • Gently lift off the LCD screen.
      • Follow iFixit's soldering guide to remove the LCD screen.
      Ask FixBot
Jonathan Hidalgo
659 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 61
All Time: 2,268
